Hi ,
     I have an error 70129 << A disabled axis has been commanded to move >>
I work with  :
- Labview 2012
- PCI -7344
- driver NI - MID 7652
- extern encoder 40,000
I use only one axis with servo motor
How can i enable this axis please ?
(6,876 Views)
Accepted by topic author k-usa
Hi k-usa,
Please make sure that all the hardware is set up, make sure that the enable switch is in the correct position:
https://www.ni.com/docs/en-US/bundle/372902b/resource/372902b.pdf
Also please try to make sure that you can run the motor in Measurement and Automation Explorer  (MAX) before running it in LabVIEW:
https://www.ni.com/docs/en-US/bundle/372324c/resource/372324c.pdf
One thing to note is that this configuration is not the one you want, but will give you a rough idea of how to change setting in MAX.
Paolo F.
(6,855 Views)
 i had a connection probleme
now is ok
thanks!
(6,829 Views)
bro.
I use the motion card PCI-7342.
I meet the same problem.(Error 70129)
How do you solve it? pls
(3,318 Views)
Hi henry_huang,
This post is a few years old. I would recommend making a new post on the forums to achieve more visibility.
Best,
Timothy D.
Applications Engineering
(3,314 Views)
I found the solution.
Open the NI-MAX, select your devices
and clip the "Initialize" button.
(3,212 Views)
