7334 digital IO
What do I need to wire up in the SCD-68 box to be able to communicate with the 24 bits of digital IO available on the PCI-7334 motion controller?
(3,725 Views)
I assume you mean SCB-68, and all you would need is an SCH-68-C68-S cable, mini 68 (VDHCI) connector to standard 68 (D-Type) connector as shown in the link below:
http://sine.ni.com/apps/we/nioc.vp?lang=US&cid=3971
(3,725 Views)
I have that. How do I know what settings to make to the switched in the box as well as what do I cable up where in the box.
Eugene
(3,725 Views)
Eugene,
Have you seen the user manual for the 7334? It is available on the NI website at: http://www.ni.com/pdf/manuals/322504c.pdf. The pinout for the DIO connector on the 7334 is on page 5-14, and the pin assignments are identical to those on the SCB-68. So you would simply connect the SCB-68 to your 7334 using the SCH-68-C68-S cable, and then break out the individual DIO lines you need from the SCB-68.
If something still isn't clear, please be more specific about which signals you want to access from the SCB-68.
(3,725 Views)
As for the software settings for these lines, you will have to configure them in Measurement and Automation Explorer. Refer to the following document for more information:
http://zone.ni.com/devzone/conceptd.nsf/webmain/081957EE013C7A4586256B92007818E0?opendocument
(3,725 Views)
