7344 FlexMotion32.dll
After many years I am getting around to using my 7344 PCI motion controller board...  I am trying to find the DLL to call from my C# program.. Where can I find the FlexMotion32.dll
And I heard that this is now called SoftMotion?
Any help would be much appreciated..
Thank you
Darryl
(7,056 Views)
Hi Defender,
Which drivers do you have installed for motion and what version are they? You can find this information in NI MAX under the software section.
(7,034 Views)
I checked out the Ni Max and under the NI-Motion 8.1 the device driver version is 8.1.0.3037
Thank you for responding to my request....  From the device driver, what can you tell?
Cheers
Darryl
(7,023 Views)
Defender,
The first link below is for the latest version of NI Motion drivers which will get you up to date.
http://www.ni.com/download/ni-motion-8.5.1/4355/en/
The second link below is a similar forum post asking how to call the same dll in C#. It is the same process for C# as it is C.
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/How-to-call-the-National-Instruments-flexmot...
(6,990 Views)
Thank you very much.. Let me give this a try and see if I can work throguh it.
Cheers
Darryl
(6,971 Views)
