01-24-2006 09:56 AM
In contrast, a halt stop is immediate and abrupt. The target position is set to the position of the axis at the moment the VI is executed. On servo axes, full torque is applied to stop the motor(s) as quickly as possible. On stepper axes, the step pulses are immediately ceased.
01-25-2006
06:10 PM
- last edited on
07-11-2025
08:21 AM
by
Content Cleaner
The behavior you are describing sounds like the response of a halt stop when a following error exists in a closed loop stepper. When a halt stop is performed on an axis the following error is cleared and the holding force on the motor is removed. This is a known issure for NI-Motion drivers prior to 7.2, and is fixed in that release. You can download the NI-Motion 7.2 driver here:
NI-Motion Version 7.2 for Windows 2000/XP
http://digital.ni.com/softlib.nsf/websearch/a38d3ad4a8b0f200862570f100758773
01-26-2006 08:17 AM
01-27-2006 02:18 PM
