7344 with the incremental encoder
Hi
     The system uses the 7344 control and UMI7764 with the incremental encoder feedback. Before the system is power off, I want to record the value of the encoder to the flash ROM of the 7344. Then next time,  I can read  this value to know exactly the status of the system when it is power on.
      But the question is that it doesn't work when I try to solve this with the Object Management nodes. So, will you please give me some instructions or maybe some example code like this?
      Thanks in advance!
(3,591 Views)
Could anybody please give some instructions?
Thanks!
(3,577 Views)
hello,
         r u connecting incremental encoder to UMI,
I have some problems in connections,
will you help me?
(3,206 Views)
