A question about synchronizing motion and data aquisition
I use the motion control board to create 2D movement(row by row),and use the DAQ board to inspect the signal.
I route the the pulse from the encoder via RTSI to trigger the DAQ to aquire data.
To create XY grid movement,I use the vector space to define the positon. Then I have a question :when the positon I define is (0,Y)
,is there a pulse in the encoder 1? If there is no pulse ,the DAQ will not aquire the signal in the positon
昨天是今天的昨天
明天是今天的明天
今天是昨天的明天
是明天的昨天
(3,035 Views)
When you move from (0,0) to (0,Y), only the second axis will rotate. Therefore, no pulse will be sent will be sent from encoder 1 to your DAQ card. A possible work around is to use breakpoints which will allow you to send a pulse when certain positions are reached. For more information on this, please refer to the attached example.
(3,019 Views)
