AC LVDT or DC LVDT
Hello, I am in need of an LVDT for position measurement. I am currently building a tensile tester.
The LVDT needs to have speed and position control. I'm not sure what LVDT to go with and whether it should be AC or DC.
Can someone point me in the right direction? Thank you!
(6,264 Views)
Hello NiUser123789,
Do you already have some NI hardware?  Is it PXI, SCXI, cDAQ etc? Your choice of LVDT may be influenced by the hardware you have available.  Here's a paper that talks about using LVDT's with NI hardware:
https://www.ni.com/en/shop/data-acquisition/measuring-position-and-displacement-with-lvdts.html
Have you looked at any models in particular?
Mason M
(6,200 Views)
