AKD how to change IL.LIMITP
Is there a way I can set and/or read the AKD parameter IL.LIMITP programmaticaly in Labview. This is the application peak current, positive direction.
I'm using the NI Softmotion library but doesn't seem to have the ability to change this parameter.
I'm using AKD-P00306 drive, AKM21C motor using ethercat to a cRIO-9035 on Labview 2017.
(2,279 Views)
Sadly it seems like no:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OtvSAE
CH
Applications Engineering
http://www.ni.com/en-us/support.html
(2,238 Views)
