ASK for help about the different velocity configuration in multiple axes through the labview code
first thank you for your concern my question
my application is six axes monitors, every two axes motors do the same motion. I meam the two axes motors connect to the one system they have move synchronously with the same velocity . just  use the two motors do the job like using one motor. NOW I use umi 7774,it has for axes interface. I want to use one axs interface to control the two motors, I mean through the one axs inerface send the same control signal to the two motors. then I can use the three axes interface of the umi to control the six axes motors multiple motion
IN FACT, my application is simple, I mean the six axes montiors  every two axes motors is one group and do the same motion . and the motion is straight-line just front and back.
other two groups motion trace is also straight-line , what I need to do is control the three group motiors move following the set schedule,velocity and position  SO the three group monitors do the straight-line motion at different schedule ,velocity and position. but from the labview program I HAVE TO PROGRAM TEH LABVIEW CODE IN THREE-D MODE AND I CAN CONTROL THE THREE GROUP MOTORS  OR THERE IS SOMETHING ELSE WAY TO SETTLE MY QUESTION??? HOW I CAN SET THE DIFFERENT VELOCITY IN THE THREE GROUP MOTIORS. AND I FOUND WHEN YOU SET THE VELOCITY IN LABVIEW ,YOU JUST SET ONE VELOCITY , I NEED THE THREE DIFFERENT VELOCITY TO THE THREE GROUP MOTORS,  HOW DO I PROGRAM???
I AM LOOKING FORWARD TO YOUR HELP
Message 1 of 1
(5,783 Views)
