Allmotion Driver VIs
Has any one used all motion driver boards with labview?  I can not make any of these VIs work with labview 2009.
http://www.allmotion.com/software_labview/labview.htm
(3,635 Views)
Hi Nick,
Could you please be a bit more detailed about what all isn't working?  Are you getting any sort of timeout error?  Are you able to establish communication with the boards at all?  Are you using the USB to RS232 converter mentioned in the linked document?  And, had you gotten this to work with LV 7.1 or 8.0 that the programs were written in?
Marti C
NI Medical
(3,628 Views)
