Applied Motion ST5si vi
Glad to help.
Message 11 of 18
(1,292 Views)
Resurrection apology.
I've just been using this code to talk to a Applied Motion TSM 23Q over RS485.
I also have the timeout error, how did you solve that? termination?
Message 12 of 18
(640 Views)
So it was working and now it isn't?  Only a specific command?
Message 13 of 18
(629 Views)
HI, I'm not the original poster. Dave last reported that he had a timeout error and solved it by 'termination' whatever that means. I've been trying your VI's and have the same timeout error.
Message 14 of 18
(599 Views)
Hi Highland Controls.
I'm using your Send Serial to talk to a TSM23 motor. (Many thanks, great work)
But i'm getting a timeout error 1073807339. Now usually that beacuse its waiting for bytes that a'rent there.
In your .vi you've made a read of a constant 100 bytes, which would seem to be more than the drive sends.
Why have you done it this way and not a bytes at port?
Any ideas on the timeout?
Message 15 of 18
(539 Views)
If the termination character is enabled when opening the com port(and my Applied Open Com Port VI does this), then the byte count is just a maximum.  Is any command working?  Post a screenshot of your code.
Message 16 of 18
(531 Views)
I seem to have at least one read before it times out. I'm just in the process of hooking up a scope to have a look at the data. But perhaps before i do that i'll check out the termination char. I must admit i thought the previous poster was talking about RS485 line termination.
I have had your Open, close & send serial working in a small test app, before putting into my main vi, so was thinking it was a timing or clashing. Hence everything moved to a sequential, and some delays put in places (Applied HCR calls for 30ms between most writes, but 'I' commands can be done with 1ms. Hence the fast/slow command delay waits.
...haha found it mid typing.
Looks like your Open vi has a bug, it specifies 'D' as the termination rather than '0D', that would be what the previous poster was refering to in a rather oblique way.
Message 17 of 18
(514 Views)
ah no, me being stupid, that was just it stripping the 0 in the constant. Still have the timeout.
Message 18 of 18
(511 Views)
