Are there any vi's that model ac induction machines on this site?
I am making a vi to model an AC induction machine given the mechanical torque (Tm) or the shaft velocity (omega_r). If this already exists I won't add my own (because it is rudimentery). It seems like it should be here, but I can't find it.
The beginning of my vi is attached (it just takes shaft velocity now and needs to run twice due to a problem with local variables.)
(3,850 Views)
Hi Tinkerer,
I am not aware of any already made VIs which ship with LabVIEW that are already coded to do what you are describing.  However, I have taken a look at what you have already written, and it looks like you are off to a pretty good start.  I am not exactly sure what your final application will be, or your design process along the way, but you might be interested in the Control Design and Simulation Module.
Wes Pierce
Principal Engineer
Pierce Controls
(3,833 Views)
Thank you for the reply.
You're right in thinking that this will be a part of a (vector) control system. The toolkit looks good for designing the control system and for determining the minimum set of parameters from a physical machine. The vi I am making will take one of those state spaces and find all of the other variables associated with the machine. This is done in Simulink (somewhat) and the toolkit says it imports from simulink.
I'm attaching an update.
(3,822 Views)
