Breakpoint Pin Axis Assignments PXI 7354
I've had a customer dig a legacy project up from the dead and I am looking for a bit of information on the PXI-7354 / UMI 7774 combo with regards to Breakpoint
First I should say that the code is all working, I am just looking to tidy up some paperwork.
I am using (successfully) breakpoints on Axis 2.  I have to document a cable for the customer so they can order a spare, and I've found that the old connector configuration means that I used Breakpoint 2.  This isn't counter intuitive if BP1=Axis 1, BP2=Axis 2, etc.
The problem is that I cannot find documentation anywhere that specifically defines this.
Furthermore, in the code (over 5 years since I've looked at it) the only BP configuration seems to be the Axis number, which then points to the Axis1=BP1, Axis2=BP2 etc.  But I'd love to find where this is explicitly defined for my peace of mind.
Anyone?
Wes
Wes Ramm, Cyth UK
CLD, CPLI
Message 1 of 1
(2,079 Views)
