Buffers
Hello I have 4 Axes with totally independent moves
I woud like to make 4 Buffers, one for every axe.
There are diffrent sizes of the buffers, each one up to 2000 points (but sometimes there are only 200)
Is it possible to place to buffers in the Memory so that they don't effect ceach other?
(In other words can I set the start byte of the Buffer)?
Thax for U'r help
(3,350 Views)
Dear Eutak,
please take a look in the Motion Palette.
-> Trajectory Control -> Buffered Operations.
Here you will find some VI's to work with buffer operations.
Hope this Helps,
best regards.
SebastianN
(3,350 Views)
Oh belive me I already had a look at them. The problem is another (Sorry is my fault I didn't explain the situation clearly).
For 1,2 or 3 dimensional Vektorspaces I can accuire one Buffer only; for 4 axes i must accurie a Buffer for each axe, since there is no 4 dimensional vekorspace. Now I want to split the whole on-board buffer of 16000 Data Points in 4 Buffers of 3500 Data Points; How can I set the start Byte of the second Buffer to Byte 3500?
(3,350 Views)
