C/C++ Programming Reference
I am just getting started on a project where the NI-Motion 7334 controller board was selected to control 3 stepper motors (most likely in open loop mode).  I plan on writing the application in Visual C/C++ 6.0.  The only programming reference that I can find is the "NI-Motion C Reference Help" file.  Is there a better rerence guide suitable for printing?
Also, any information on setting a a project in Visual Studio would be much appreciated.
Thank you.
Chris
Message 1 of 8
(5,671 Views)
Hi Chris,
The C reference help is the best list of functions that we have.  But here are some Knowledge bases that will help you get started with Motion in C++.  If you are using the Motion Assistant then this will help you convert your script to C code.  I hope this helps.
Have a great day,
GG
Message 2 of 8
(5,647 Views)
Hi Chris,
The best reference for NI-Motion functions is the help file that you mention. You will find some basic and simple C examples in “\National Instruments\NI-Motion\Documentation\Examples\NI-Motion User Manual\C” directory. Those are examples written for console mode (DOS applications).
To use them you will have to create in VC++ .NET 2003 a Win32 Console Project (I don’t remember anymore how this option was called in VC 6.0). Select the “empty type”. After you do that, just add to the project the example file you want to use and set the compiler to use FlexMS32.lib as instructed in the comments located at the beginning at every example code.
For Windows/MFC applications is basically the same, you just have to use the VC Wizard that creates an MFC application, include FlexMont.h file and set the compiler to link FlexMS32.lib import library.
Hope this help.
Best regards.
Message 3 of 8
(5,617 Views)
Hi I'm trying to develop an application in visual C++ using functions from NI Motion, to control linear motor guides through NI PCI 7356 Motion Controller.
I have written and compiled some of the C example programs that come in the NI Motion examples folder succesfully, but they are only written for Win32 Console Application. I would like to know if it's possible to define classes (to encapsulate code) and create Windows form applications (to create graphical user interfaces), in visual C++ 2008 or if it's only possible in console application. Also when I define a class in Visual C++ (Console application) and declare and object of that class (that contains NI Motion fucntions) I get some errors after compiling (This is not the case If I only define a routine and call it in the void main(void) method).
I hope you can help me or give some advice.
Thanks.
Arturo Marban
Message 4 of 8
(4,784 Views)
Hey Arturo,
What sort of errors are you getting after compiling. Also, your question might get a little more attention if you create your own thread and simply reference this one, as this thread has been idle for a few years.
Hope this helps.
-Ben
WaterlooLabs
Message 5 of 8
(4,762 Views)
Hi Ben,
Now I'm trying to create and application (Win 32 Project) using Microsoft Foundation Classes (MFC) instead of Windows Form App. My purpose is to create a graphical user interface to control a three axis milling machine through NI PCI 7356 Motion Controller. I will list you the problems I have had:
* First, I tried to build a GUI using Windows Form App in Visual C++ 2008. It is something simple: a window with a push button. Nonetheless, if I simply write  the header #include "flexmoth.h" in the code section of the widows form app, I get many errors (102 errors) after compiling. The error text is:
          C:\...\flexmoth.h(180) : error C3389: __declspec(dllexport) cannot be used with /clr : pure or clr/:safe
* Second, I build a GUI with two buttons using MFC, and it seems it works, but I think it would be easier programming using Windows Form App, because I have to add more controls (push buttons, radio buttons, combo boxes, etc...).
I'm not an expert using visual C++ and it will be helpful for me if you give me some advice.
Arturo
Message Edited by arturo_1982 on 01-28-2010 12:28 PM
Message 6 of 8
(4,757 Views)
Message 7 of 8
(4,744 Views)
Hey Arturo,
Are you meaning to include 'flexmoth.h' and not 'flexmotn.h'?
Hope this helps.
-Ben
WaterlooLabs
Message 8 of 8
(4,727 Views)
