CD.VI G(s)
Hello everyone !
It's my 1st time to post a question here, I'm CLAD but very new on using control system design toolkit.
my problem after installing the control system design toolkit, it ONLY provided me PID/FUZZY VIs, but it doesn't provide me the transfer function VI, root locus...etc
however when hover over on transfer function example on the example tap, it says it needs to provide the control system design toolkit and it's hyperlinked, when I press on this phrase, it redirects me to the same library I downloaded and installed !
(2,732 Views)
Accepted by topic author YoussefAliSabri
I believe PID and Fuzzy logic are installed with LabVIEW by default (for newer versions at least). I suspect you might be installing a version of Control Design and Simulation which doesn't match the version of LabVIEW you are using. Which version of LabVIEW and what bitness (64 or 32 bit) are you using? Note that Control Design and Simulation was not compatible with 64 bit Labview until LabVIEW 2016
(2,686 Views)
Thank you so much for your help and your time
(2,247 Views)
