Can I Connect a 6-wire Unipolar Stepper Motor to the MID-7654/7652?
I am trying to connect a 6-wire unipolar stepper motor to the MID-7654/7652  motor driver and was wondering how the wiring would work on that?
(4,186 Views)
Jay_Team5:
It will not work since that drive is for Servo motors only, not Steppers.
-AK2DM
(4,184 Views)
Can it still be hooked up to the Step/Direct inputs?  The user manual mentions that those are the inputs that you should use if you want to control both a stepper and a servo motor, I am just not sure how that can be accomplished.
(4,180 Views)
The connector is simply a pass-through for the signals generated by the motion controller card for hooking up to a separate driver compatible with stepper motors. It would be used if you had a combination of servo and stepper motors in your system used in conjunction with separate servo and stepper drives.
-AK2DM
(4,177 Views)
