Can I set up motion assisst to work in distance instead of pulses?
I am trying to motion control with a MID-7604 Driver and Motion Assist software. I would like to work in mm on axis 1 and degrees on axis 2 but I don't see a way to change the setup from pulses to distance.
(3,293 Views)
Sorry, but this is not possible in the first version of Motion Assistant. The Motion Assistant is basically a prototyping tool. You can do the scaling from steps to physical units later in your application.
Jochen Klier
Applications Engineering Group Leader
National Instruments Germany GmbH
(3,293 Views)
Thank You for your help.
Nick
(3,293 Views)
