Hello!
I´m using PXI-7358, UMI-7774 to control Faulhaber servo motor 2036U 012B (together with the amplifier Faulhaber BLD 5603 CC4P, current control modus).
In my application, i should monitor the torque of the motors.
"Read DAC.vi" is used to monitor the output command from the PID loop. When the DAC output is connected to a torque block servo amplifier, you can use this value to calculate motor torque or to monitor the acceleration and deceleration portions of a trajectory to see how close the control loop is to saturating at its maximum torque limits. (from NI-Motion VI help)
But how? I can get the DAC value (in Voltage), i have torque constant and No-Load-Current. But where can i get the so-called "Amplifier Gain" (Ge), in order that i can convert voltage value to current value?
Can somebody help me?
Thanks a lot!
WLAN
