Can i use NI-7358 to implement a hybrid position force/torque control system?
thank you Jochen! I'll ask you if i have new questions.
by the way, i found a new mini-camera that are suitable for my application, can you suggest a good control solution for that:
STC-R640 Series Color Microhead Board Camera (Company Sentech)
http://www.sentechamerica.com/oemremotecolorboard.htm
thanks for your reply!
WLAN
Message 11 of 18
(2,927 Views)
This camera provides an analog NTSC color signal which can be acquired with a PCI-1405 camera.
Jochen Klier
National Instruments Germany
Message 12 of 18
(2,924 Views)
thanks Jochen!
i have forgot on thing:
i will use 2 cameras to implemnt a stereo vision system.
Must i buy two card? or is there another better way to solve this problem?
WLAN
Message 13 of 18
(2,923 Views)
WLAN,
in this case there are several options. Could you please specify your needs a bit more detailed? Do you need color acquisition? Do you need tight hardware synchronized acquisition from both cameras?
Jochen
Message 14 of 18
(2,921 Views)
yes, i need a tight hardware synchronized color acquisition because the operator must see the frame and feed the force and do the movement at the same time, or he will make not reversible error...
pls suggest some options!
thanks you very much!
WLAN
Message 15 of 18
(2,916 Views)
In this case two PCI-1405 would be the best option. You can synchronize the boards by using the external trigger I/O.
I hope that helps,
Jochen
Message 16 of 18
(2,903 Views)
Hello Jochen!
i need now more than 3 PCI-Cards... it is too much!
i'm thinking whether i should buy a PXI-Chasis and PXI-Cards.
Can you suggest me which pxi-products i should buy to use in my application (robot motion control, robot force control, stereo vision system, synchronisation)?
WLAN
Message 17 of 18
(2,810 Views)
WLAN,
thank you for your interest. I think this type of request should better be addressed by an NI sales engineer. Please send me an email with your contact data and I will forward your request to the appropriate person.
Please email to jochen.klier@ni.com
Jochen Klier
Message 18 of 18
(2,807 Views)
