Can not configure PXI embedded controller + Motion controller in LV-RT with MAX
Hi all,
I just got the LV-RT add on, I am using 8.2.1 version. Here's what happened:
- I have a target PXI-1042 (chassis) with PXI-8106 Embedded Controller, and one motion controller PXI-7358 is installed! And host, Intel Pentium Duo Core with high spec.
- I followed the instructions , I have installed the LabVIEW and LV-RT to both, my PC and the PXI controller
- Then, I booted with the PXI embedded controller, chose to boot from LV-RT in the BIOS, then I managed to set the IP address in the target, and also I
successfully install the driver/software from the host to RT-Target (my PXI)
- When I was about to do the next step which was to configure the device in MAX, I failed. The MAX seemed can not read the devices which are installed
I have searched in ni.com, looking around the RT thread but no-one seemed to have same problem with me sad.gif
FYI, I have installed the driver for the motion controller, which I can write and run a program for this controller.
Do you know how to solve this problem? Thank you
(3,990 Views)
Hi all,
I solved the problem. Here what I did:
1. I downloaded and installed the new version of VISA 4.2, LabVIEW Run-Time Engine 8.2.1 (to make sure it was up to date)
2. I booted to LV-RT NOT LV-RT Safe Mode, and my devices show in the panel
Thank you for your help
(3,977 Views)
Hey Bono02,
I'm glad that you were able to figure out what was wrong.  Hope things are going smoothly now.  Let us know if we can help you out in the future!
Take Care,
Evan D.
Installer R&D
(3,960 Views)
