Change direction for find index is not possible
I am using a National Instruments motion controller 7344. Axis 1 and 3 with servos and axis 2 and 4 with stepper motors with feedback. Because the use of axis 1,3  and 2,4 are identical the configuration in MAX is equal. All axes works well except for find home / index.
I start with find forward limit switch on axis 1 and 3 go ahead with find home. The next step ist to find index on all four axis. The problem is that axis 1 search in reverse direction and axis 3 in forward. What ever i Try - change direction in MAX or thrue function call - neither axis 1 nor axis 3 were possible to change the direction.
If i elide find forward limit switch the find home is not always secessfull. At home switch the the direction changed but the move does not stop.
I am using MAX 7.2.1
Thanks for any help.
(3,105 Views)
The same or at least very similar question was discussed in this thread. There is a LabVIEW vi attached that works properly on my test system with the same NI-Motion version (7.2.1) that you are using.
If you are not using LabVIEW please make sure that you configure the correct findType (NIMC_FIND_INDEX_REFERENCE) and the corect attribute (NIMC_INITIAL_SEARCH_DIRECTION) when you call flx_load_reference_parameter().
Jochen Klier
National Instruments Germany
(3,097 Views)
