Closed Loop Control of stepper motor using linear position sensors
Greetings,
I use a stepper motor with timing belt to enable linear motion in an axis. I can get absolute linear position information with the help of linear sensors and convert them to actual step data using math operations. I was wondering how I can feed this data back to the VI that moves the motor and create a closed control loop. Overshoot and number of pull in's are not a problem as long as the final position is correct (or within a certain tolerance).
My setup is as follows: PCIe 6321 and BNC 2110 for position measurement
(4,316 Views)
For some reason I couldn't edit my first message which I sent out accidentally before it was complete.
Here's the full version:
 Greetings,
I use a stepper motor with timing belt to enable linear motion in an axis. I can get real time absolute linear position information with the help of linear sensors and convert them to actual step data using math operations. I was trying to find a way to feed this data back to the VI that moves the motor and create a closed control loop using LabView (not MAX). Overshoot and multiple pull in's are not a problem as long as the final position is correct (or within a certain tolerance). I was wondering if it was possible to feed the actual step data (which I received and calculated from linear sensors) to Movement VI's in LabView as "desired position" value? Is this possible? If not, does someone have another suggestion?
Thank you.
PCI7332 and UMI  7772 for motor control
(4,308 Views)
