Combine cRIO 9076 and cRIO 9081
I have two FPGA real time controllers: cRIO 9076 and cRIO 9081.  Due to not having the latest version of LabVIEW (2011), I am unable to use cRIO 9081.  Since cRIO 9076 has only 4 slots for the modules, I am thinking of using cRIO 9081 as a slave just to add more modules on its slots.  Will this work?  If so, how can I connect cRIO 9081 to cRIO 9076. Any suggestion is appreciated.
(6,235 Views)
Accepted by topic author ExcelX
Hello ExcelX,
Unfortunately, there is no meaningful way to interface with the 9081 without having the correct versions of LabVIEW (at least 2011) and NI-RIO (at least 4.0). It does run windows, so you could in theory boot it up in Windows and attach a monitor to it, but you wouldn't be able to run any code on it.
You could download the trial version of LabVIEW 2011 and use it with your 9081 for thirty days. But I recommend just upgrading to LabVIEW 2011 - the 9081 is a powerful (and expensive) CompactRIO.
Colden
(6,222 Views)
