Compatibility Parker drivers
Hi everyone,
I'm new to the NI system and would like to control the PD-10P motor driver from Parker with a NI PXI controller card. I have been looking at the PXI-7344 in particular, do they connect well together? I did not find a list of the approved motor drivers, how can I check if a driver is supported by a given controller card?
Alex
(3,932 Views)
We do not have a list of supported drives, however most third party drivers can be used with our NI Motion boards by using an UMI to interface between the two.
Through the UMI the appropiate signals should be connected between the drive and the board, so that it can enable it, and configure its different settings.
(3,905 Views)
Great thanks I'll get one then
(3,903 Views)
