Connecting input signals on NI ISM-7411 Ethernet stepper
I'm using 7411 and made it work with configuration utility and LV basic example(Axis Straight Line Move - Ethernet Stepper).
And now I'm trying to use enable input(EN) to stop and move the motor.
I followed connection from the manual like below and enabled using EN input on configuration utility.
I tried several ways like connecting EN+- to SMPS +- and cut off power from SMPS or connecting DIO(5V) to EN+-, setting EN Input as Enable motor when closed/open(both ways)
But I still cannot stop the motor with EN input.
What should I try? Please give me some comment with connecting input and writing / reading properties / methods.
Thanks.
YoungMin
(4,406 Views)
YoungMin,
The Enable input when in Ethernet streaming mode is remapped to become a home switch input. The latest version of the manual has been updated to reflect this, and this KB describes the wiring.
(3,509 Views)
