Contour move: Interrupt
 Hi ,all
 I have faced several problems when using contouring function.
 Below is the code which I modified from the sample. I load a series of points and then send to contour move to complete the motion.
 However, I don't know how to interrupt the contour motion. In other words, if something happens when the contour move is executing, I want to stop the current contour move and change to another new trajectory.
 Another problem is I cannot adjust the requested interval. The default value is 20ms, but when I change it to 200ms, the error 70078 occurs: parameter out of range.
Thanks so much if anyone can help me ~
Message 1 of 1
(4,912 Views)
