04-07-2006 11:43 AM
Yes I have no problem controlling the motor with the SCL Utility. I have used the utility to put the driver in SCL Mode (PM2).
Im not sure what you mean by append a carriage return-line feed. Did you use a VISA node to send the characters to the serial port? Could you possibly send me a screen shot of the Block Diagram?
I have spent most of my time trying to send commands using an example VI called Labview<-> Serial.vi For the most part, the motor has not responded to any of the commands I sent it. However yesterday I got the motor to move once, and have not been able to repeat that. I was tinkering with the termination character stuff in the VISA Configure Serial Port.vi 'Sub-VI'. I read something in the help file that said the termination character should be 0xD if commands must be terminated with a carriage return. I have no idea why the motor is not responding in the same way again.
Tristan
04-07-2006 12:00 PM
Tristan-
Use the default settings for the com port. You should be able to get going from this screenshot.
Brian
04-07-2006 01:00 PM
Thanks a lot Brian, I am working on putting this together. Since I am not familiar with a lot of the nodes in LabVIEW could you send me a screen shot of the front panel as well?
Tristan
04-10-2006 08:34 AM - edited 04-10-2006 08:34 AM
Message Edited by Irene C on 04-10-2006 08:34 AM
04-11-2006 04:54 PM
04-08-2009 12:49 AM
04-08-2009 01:23 AM
04-08-2009 05:38 AM
06-11-2009 10:42 AM
I have also been following this post.
The Applied Send Command.vi has been very helpful for me, so thank you for publishing it. However, I have an Applied Motion Products STM23S-3RE motor connected via a USB-RS485 hub. The motor has an internal encoder, and I am having trouble talking to it. Shouldn't the feedback just be showing up on the read buffer indicator from the VISA read node?
Thanks for your help,
Ross Wehner
rwehner11190@yahoo.com
06-11-2009 11:11 AM
