Control Stepper Motor Driver by Labview
I bought two stepper motor drivers and want to control them through LabView, which type of PCI card I can use?
It's the Twotrees TB6600 Stepper Motor Driver 4A 9-42V CNC Controller.
Thanks!
(2,837 Views)
Hi BinDong,
 I think you need to find a motion vendor to provide you suggestion and most of motion cards in the market can control the stepper motor.
Below is your driver and has 6 different signals need to be connected to motion card and also need to connect limit signal,home Signal.... to motion card.
  After you buy motion cards, you will get VI or DLL example from vendor that you can write  LabVIEW code by yourself.
Ricky
(2,758 Views)
