Control Stepper Motor via DM452T Controller and Arduino
I am working on a project to control a stepper motor via labview with arduino's help. I am not an expert in labview so I need some help with programming and if someone used the DM452T can tell me about its correct connections because to have fault connections I would be very grateful to you, guys. Thanks you in advance.
(2,999 Views)
I was able to connect the driver and the stepper motor, I've controlled them via Arduino.
I was able to make a trial program for the stepper motor and it's working very good.
Right now I have a small issue, my project is very sensitive and accurate and I will need to know the exact distance that the motor move BUT when I run the program to make the stepper motor rotate for a full revolution, it rotates a full revolution and about 4-5 more steps with a certain speed that I cannot change. It's something like an initialization with the labview program for the stepper motors. This happened with me before while working with servo motors but it wasn't necessary to eliminate this error. I don't know if they have the same reason.
Can anyone help me to eliminate this few, please? I would be grateful.
(2,954 Views)
Here's a video to explain more of what's happening..
https://youtu.be/6mB-YB1ZRoc?t=20
and a screenshot for block diagram of the program
(2,945 Views)
