Control two stepper motors with PCI 7332 for sinusoidal movements
I am now using two stepper motors of RK566BAE (Oriental motor). I connected those two motors with UMI-7764 and PCI-7332. I designed to have independent sinusoidal movement of each motor. The first motor is wired to Axis 1 and the second to Axis 2 (of UMI-7764).
I want to use Ni-Motion to create  a single VI in LabVIEW which helps to control both motors. But I have not figured-out how to obtain the movement I desired.
Could you please advise me.
Thank you so much.
Message 1 of 1
(5,557 Views)
