Controllin​g Newport SMC100 with Labview
Dear all,
I need to control a single axis Newport motor via Newport SMC100, i installed the SMC100 labview drivers.
Do anyone have examples? OR anyone can show me the way about how can i implement my system very fast?
Please have a look at the brief description of my system:
I am also measuring load with "load cell,amplifier and DAQ (NI USB-6343, X series)" so what i want is to trigger SMC100  after a certain value of load cell is reached.
Do anyone has any idea how to work this out? is this so hard application for a beginner? :smileyhappy:
This is my master thesis's test setup so i am really looking for help.
Best regards from Turkey!
(6,555 Views)
Hi Kindly-Wisher,
It looks like you have already created a Discussion Forum for this topic (How to interact Motor Controller with Load cell via LabVIEW).  Please try and keep a topic to just one thread.  You can reply back to that thread if you still have questions.
(6,547 Views)
I have a problem in controlling SMC100 Newport.
How to modify the home position of motor?
At the first time of opeation, I need the motor go to specific position, not at 0 position.
Thanks in advance
(3,280 Views)
Hey neni21,
Since this post is rather old, it is probably better to open up a new forum post next time so you can get more visibility.
You'll most likely need some type of switch to locate your motor position limits and then work to set a new home position from there. You should set your switches to the designated home position you are needing.
(3,272 Views)
