Controlling 8 DLDC motors with myRIO
Is it possible to control more than 4 brushless DC motors with a myRIO controller? I have 2 Motor Adapters from Digilent and a sabertooth motor controller.
I have a project that requires around 8 BLDC motors.
Is it possible with this set up? if not, what is the maximum number of motors that I can control with this? I believe that it is 6, but I am not 100% sure.
Thank you in advance!
(2,944 Views)
What kind of input needs your Motor Adapter from Digilent?
(2,915 Views)
I’m not quite sure what you’re asking but here is the link to the digilent adapter that I have (2 of them):
https://store.digilentinc.com/motor-adapter-for-ni-myrio/
i need to be able to control the direction and speed of the motors.
Thank you!
(2,909 Views)
From that webpage it looks like you can control 2 DC motors throught the MXP connection of the MyRIO. If you have 2 MXP ports you could probably connect 2 of these boards which would give you control over 4 motors.
-TyVo
(2,897 Views)
