08-23-2006 04:03 AM
08-30-2006 04:21 AM
Hi Mal,
There are some good getting started resources, which will probably be the best place to start if you are new to all of this. Check out the following links:
Getting Started with NI-Motion for NI 73xx Motion Controllers
http://digital.ni.com/manuals.nsf/websearch/D512386E60CA8ADF862570AF0076894A
NI-Motion User Manual
http://digital.ni.com/manuals.nsf/websearch/983F38925A4F0D16862570AD0054C641
There is also a great resource on the Developer Library at ni.com which gives lots of tutorials and examples for Motion applications
http://zone.ni.com/devzone/devzone.nsf/webcategories/69771825AE23E98E86256786000BEA02
The other place to look would be the LabVIEW example finder, there should be Motion examples installed here which should give you a working starting point.
I hope this helps
Hannah
NIUK & Ireland
08-30-2006 11:17 AM
Hi
Thanks. I ll work on the links that you gave me.
Mal
