Converting a master follower type Cam Grinding Machine to CNC
I was searching for information about cam grinding machine conversions and saw website that talked about  Converting a Master follower type Cam grinding machine to a machine
that uses data files which contain lobe profile information to control the movement of the machine. The website had information about the conversion which said they used National
Instruments Hardware and LabView Software to control precision servos. The company mentioned in the Website was MAYURAS this company apparently is in India. I've Had no luck contacting them.
We own one of the Master Follower Type Machines and for years I have considered converting it to Computer Numeric Control. We already Generate the precise  profiles using
in house software and software purchased from other vendors. The software generates files accurate to .000001" Unfortunately  the masters we generate now are only accurate  to .0005"  this is because our Vertical machining centers are only accurate to .0005"
     My company has used National Instruments CVI package to generate a Software package for adjusting and monitoring our Engine management System. We have been using the CVI package for over 10 years to control our Hardware.
(5,241 Views)
Did you have a specific question on this topic?
Zach C.
Field Engineer
Greater Los Angeles
(5,230 Views)
I had hoped to contact someone who had converted this type of machine to find out more about the hardware and software used. Also to get a better idea of how well
the converted machine has performed over time and what the cost of the conversion might be.
(5,223 Views)
