Create a rotatory control system
For increase the efficiency of check barcode tape , we need to construct a motion control
system . There should be two reel , one is used to load barcode tape not checked (source),
and the other is used to load barcode tape that is check passed(target) . So when the
system running , the diameter of source tape reel will be litter and litter , and the target
reel's diameter will be bigger and bigger . Once there is an error of a barcode label is found,
the motor should stop immediately , so that one can rip off the improper barcode label from the source reel, and then continued the check process . Please advise me , to construct such a motion control system , what components must be prepared ? Are there any othere important thing need t
o be considered ?
Your advise is highly appreciated.
David
Message 1 of 1
(3,341 Views)
