DC Motor Controlling with ANSI C & DAQ Card
I have 2 DC motors and a sensor. I have a NI Daq Card and i have a NI Connector board. I am trying to control DC motor with based on sensor values. Based on the conditions motors should move forward or backward. I am also using motor driver, i already connected my DAQ Card to computer and Connector block and i connected my motors to motor driver and my motor driver to connector block. And i also connected my sensor to connector board.
I gave you a HIGH LOW example which is ritten in PIC BASIC. What i am trying to learn is how i will write in ANSI C and use with DAQ card. And with which function i can read the value of the sensor? Normally if i read port in PIC Basic i will easily read the value.
I checked the DAQ CARD ANSI - C Examples but they aren't too clear. So this i just wanna ask someone who know this.
And to show what i exactly mean, here are some code written in PIC BASIC
INPUT PORTB.0                          ; Light Sensor
OUTPUT PORTB.3                     ; Left Motor Forward
OUTPUT PORTB.4                     ; Left Motor Backward
OUTPUT PORTB.5                     ; Right Motor Forward
OUTPUT PORTB.6                     ; Right Motor Backward
; to make code easy to read we are defining symbols for our ports:
SYMBOL             LSENSOR                 PORTB.0
SYMBOL             LMOTORF                 PORTB.3
SYMBOL             LMOTORB                 PORTB.4
SYMBOL             RMOTORF                 PORTB.5
SYMBOL             RMOTORB                 PORTB.6
Our functions:
TURN_RIGHT_FORWARD:
HIGH   RMOTORF
LOW   RMOTORB
LOW   LMOTORB
LOW   LMOTORF
TURN_LEFT_FORWARD:
HIGH   LMOTORF
LOW   RMOTORB
LOW   LMOTORB
LOW   RMOTORF
GO_STRAIGHT_FORWARD:
HIGH   LMOTORF
HIGH   RMOTORF
LOW   LMOTORB
LOW   RMOTORB
GO_STRAIGHT_BACKWARD:
HIGH   LMOTORB
HIGH   RMOTORB
LOW   LMOTORF
LOW   RMOTORF
(3,625 Views)
Hey there,
I noticed that you have posted here (http://forums.ni.com/ni/board/message?board.id=250&message.id=31497) and got some answers
Might be worth sticking to that forum.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,609 Views)
