Direct USB access from Labview?
A USB port cannot be comparred to a seriel port or RS232 connection, but is it possible using Labview software or similar, to have the two Data-pins of the port generate a digital on/off signal or even a PWM-signal. Is the USB communication protocol to rigid for this use?
soeren
(4,581 Views)
Accepted by topic author soeren
Soeren,
in LabVIEW you can access the USB port directly through VISA functions, but this doesn't give you direct control over the USB lines. USB always relies on bidirectional communication, so I can't think of a way to use it as a general purpose digital output.
If you are looking for a low-cost solution for USB-based digital I/Os, you may have a look at the NI USB-6501. For fast PWM generation this device is not a good solution, as it doesn't provide hardware clocked I/O pins. Hardware clocked digital I/Os are provided by the counter/timer outputs of NI USB-621x devices and by correlated DIOs of all other M-Series devices.
I hope that helps,
Jochen Klier
(4,580 Views)
No.
The USB port is generally hard-wired with a USB controller which is a hardware device which controls detecting whether the device is Hi-speed or not (pull-down resistor).  I don't think it's really useful for what is the job of a DIO card.
AFAIK interfacint with a USB port always goes over this controller which only understands the USB protocol.
Shane.
(4,569 Views)
