Does anybody have experience with using DAC channel on motion controller as a general purpose analog output?
I want to use DAC 2 on PCI7342 as a general purpose analog output. But seems it doesn't work.
Anybody has experience or example code could share with me?
Thanks.
(3,460 Views)
Got it.
Thanks.
(3,460 Views)
see the attached example I use for a PCI-7344.
You must just know that these AO have an offset: If you set "0" as input, you will perhaps have between -150..+150mV at the AO. This can be annoying depending what you do with it. However, this offset doesn't vary over the time.
In the attached VI, you can give this offset one time for ever.
Hope this help.
(3,460 Views)
Thanks PAG.
(3,460 Views)
