Does anyone have a pinout for the NI UMI to AKD Drive Cable?
I am doing some motion control with an NI 7350 card with the NI UMI 7774 breakout.  I am connecting from the UMI 7774 to a Kollmorgan AKD drive with the NI UMI to AKD Drive Cable.  This cable has a 20 pin terminal block which I beleive includes the home and limit switch signals, but I don't have a pinout of the UMI to AKD drive cable to verify this.  Does anyone know where I can get this pinout?
Chris
(6,743 Views)
Accepted by topic author kahoona137
Hi Chris,
The pinout of the 20 pin screw terminal connector of the UMI to AKD drive cable can be found on page 8 of the Getting Started with NI 7340/7350 Motion Controllers and AKD Servo Drives manual. Please feel free to let us know if you have more questions or this isn't what you were looking for.
Matt
NI Community Team
(6,724 Views)
Matt,
I had that manual, but somehow overlooked that.  Thanks for the help.  That gives me what I need.
-Chris
(6,713 Views)
Hi Matt,
Is there a similar Pin Out for the 10-Pin X8 connector on the UMI-7764. I am particulary after the connectivity of the inverted INHOUT signal.
Raja
(5,735 Views)
Hi Raja,
Take a look at the link below:
http://www.ni.com/pdf/manuals/375543c.pdf#page=37
On the drive side of the cable, the x8 connector pinout is listed on page 37.  Pin 4 is the enable line, which is different terminology for the INHOUT line.
Andrew T.
(5,667 Views)
