The PID controller is still enabled when running the motor in
contouring mode. Otherwise you couldn't do any position control at all.
On a board level the only major difference between contouring mode and
any other mode is the source of the dynamic setpoints passed to the PID
loop through the spline engine. While in contouring mode the setpoint
information comes from the buffer in the onboard RAM, in other modes it
is dynamically calculated by the trajectory generator on the board.
Jochen Klier
National Instruments Germany
