Does this 3rd party drive work with PCI 7356?
I bought PCI 7356 and AKD servo drive. However, it seems AKD can only achieve 15k rpm, which is lower than my target speed. I wonder if this drive, Analog Servo Drive S16A8 by Advanced Motion Control, will work with PCI 7356 controller. My motor is a brushless DC motor with 4-pole. I would like to run the motor at 30k rpm. The rated voltage for this motor is 24V and the rated current is 1.4A. The part number is BN12HS-13AA-02CH. I attach the spec sheet for the motor and the drive. Will this drive fit in my application? Thanks!
Chen Dan
(5,865 Views)
Hello dandan9002
It looks like one of our customers, serkanb, is running into an issue trying to use this drive with a similar card to yours.
You can view his issue here.
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/Connecting-NI-7358-and-UMI-7774-to-a-sinusoi...
Which AKD drive do you currently have?  Thank you for choosing National Instruments!
Sincerely,
Greg S.
(5,778 Views)
