03-21-2006 06:20 AM
03-22-2006 05:21 AM
Got it. I used IC7404 NOT gate to get the inverted signals of A,B and Index. It works fine.
Giridhar Rajan
Automation Engineer, Design
Cruiser Controls
Mumbai, India
03-25-2006 06:35 AM
Hey that OK you have used 7404.But I would suggest using AM26C31 which is quadrature differential line driver.
In this particular you will give the Input and in Output you will be getting Input as well as the inverted input.i.e
If you give A as an Input , In Output you will be getting A as well as A bar.
Regards
Manish karnik
Application Engineer
Mumbai, India
03-27-2006 12:42 AM
Thanks Mr.Manish. I was just wondering how I can get a perfect 5V signal at the output of 7404. You reply seems to have solved my problem. I think I should try AM26C31 driver for better results with high resolution encoders. Thanks a lot.
Giridhar Rajan
Cruiser Controls
Mumbai, India
