Drivers for PCI servo 4A card
hi
I am using Labview 7.0 and found an old PCI servo 4A servo controller which i could use. It is from the valuemotion series of products(old, now discontinued).
MAX is able to detect that there's a NI card, but identified it as a PXI system, and not as a PCI servo 4A card.
How can I get MAX to detect the card as a PCI servo 4A. Is it supported under Labview 7.0? Can I use Labview 7.0 and valuemotion software with this card?
Thanks for your time,
Venkat
(3,463 Views)
Venkat,
Yes you can use the PCI servo 4A with LabVIEW 7.0 You will need to use the Value Motion driver. There are some details on how to make this older driver work with LabVIEW 7.0 link
A Talley
Applications Engineering
(3,463 Views)
Hi
I got most of the drivers...did not read the release notes!! It works now..
Now I make it a point to read all the relevant manuals!
Venkat
(3,463 Views)
