EPOS 50/5 with sensor GP1S53 & labview
hi, I would like to ask help about EPOS 50/5 with sensor GP1S53 & labview. I have motor controller program but i'm require to connect sensor through EPOS device. Operating sensor by using labview, my sensor was connected to Signal 1(J5/2, J5/9 & J5/10) of EPOS but  was unsure how use EPOS icons to detect the sensor.  Thnx!! 🙂
(3,763 Views)
Hi DSBlue,
Unfortunately we are not familiar with the EPOS hardware and library so I don't have the solution. However, there are 2 similar threads that I hope can help you.
How to detect a photomicrosensor in LabView directly?
limit switch program for EPOS
Looks like it might not be possible to display the sensor data value, but you should be able to use your sensor as a limit switch for the motion control.
I would recommend approaching Maxon to see if they can help.
Boon Chen
(3,725 Views)
