Hi jag,
Thanks for using the NI Discussion Forums. Hopefully we can get everything worked out quickly!
This is an interesting problem, and due to the large number of steps needed to resproduce the issue, it is a problem I have not encountered before. That said, I will be doing some testing over the next couple of days to see if we can find a fix or work around for this issue. Hopefully, the 7344 does not always behave this way.
To help resolve this issue, I have a couple of questions regarding the 7344's behavior.
When you say that the motion pauses for a period of time, how long do you mean?
Does the pause occur at the rollover position, or when you change the gearing ratio?
Doe the pause only occur if you change the gearing ratio?
Robert
