Motion Control and Motor Drives
Encoder counts wrong after Firmware update to 7.2?
I recently updated the firmware of my motion controller card 7344 PCI to 7.2.
Since then a 360degree-rotation in 15degrees-steps seems to miss one 15degree-step. A 360degree-rotation stopps at 345degrees
I think that maybe the encoder counts wrong or the move function isn't executed one time.
Has anybody expierienced similar problems or has any hints?
Thx.
PS. Does anybody know a way to downgrade the firmware to the version below? It seems that the firmware update causes the problem.
(3,086 Views)
saimen54,
Odd behavior.  Is there anyway you could post the code for a simplified version of your program that exhibits this same issue.  I don't think there will be any other way to troubleshoot your issue without taking a look at the code.
Lorne Hengst
Application Engineer
(3,071 Views)
