Error 70025 in Measurement and Automation Explorer
After a clean reboot of the system I receive Error -70025 ("Return Buffer is not empty..") in the Measurement and Automation Explorer. When I click on "Clear RDB" which is supposed to solve the problem, it says "Error clearing the return data buffer". In the status tab, all LEDs are flashing (Error Code varying from 0xFFFF to 0x0182).
First, I simply tried to remove the motion controller (it's a NI PCI-7334) from the MAX tab which did not work. Then, I tried to repair the installation of all NI tools but this didn't help either.
I'm working with NI Motion 8.4 and MAX 5.4.0f0 on Windows XP.
Do you have any idea how to solve this problem? Currently, I cannot run the motor at all.
Jürgen
edit: I just realize that the controlller is listed as PXI-7334 in the Windows Device Manager but in fact it is a PCI-7334. Would this explain the problem?
update: Forcing the installation of the PCI-334 driver does not make any difference.
(5,762 Views)
Hi Jürgen,
you can find the description of occurence and solution for this error here.
Please try it.
When it dosen't solve your issue please contact me again.
Kind Regards,
Philipp K.
Applications Engineer | NI-Germany
(5,741 Views)
