Error -70038 occurred at Read Position.flx
I am suddenly starting to get this error as I start my VI.  Any ideas?
Possible reason(s):
Motion:  An unexpected error has occurred internal to the driver.  Please contact National Instruments with the name of the function or VI that returned this error.
(4,739 Views)
CAL_VG,
What version of the Motion Driver are you using and what version of LabVIEW do you have?
Luke H
(4,729 Views)
I have the same problem, Error -70136 occurred at Read Position.flx
It appears to happen when the motor starts off in the opposite direction from the previous move.
I'm using driver 5.1.1, any ideas ?
(4,617 Views)
LabVIEW 6.1
(4,615 Views)
I am using Labview 7.1.1 and Motion 7.4.0.3002
(4,609 Views)
CAL_VG,
Generally, this is caused by a corrupt driver or firmware installation. Several things to try are:
  • Upgrade to the latest version of the NI-Motion driver and update the firmware on the Motion controller.
  • Make sure that you have no NI Motion hardware connected to your computer during the installation of NI-Motion. If the controller was connected during installation, turn off the computer, remove the board, and uninstall NI-Motion. Next, manually backup and then remove the Data folder for Measurement and Automation Explorer (normally C:\Program Files\National Instruments\MAX\Data) . Then reinstall NI-Motion, turn off the computer, and connect the board again.
Luke H
(4,599 Views)
