04-09-2013 08:40 AM
I'm integrating NI 7342 motion board to control 1 axis drive in a 64 bits application.
In my application, there are some sub-systems working in 64 bits.
I can't use the WoW principe because of the others sub-systems working in 64 bits and didn't work with WoW.
So my application need to work in pure 64 bits.
Do the Flex motion library is available in 64 bits?
Are there any means to achieve my needs?
Thank you.
04-15-2013 11:51 AM
Hi rdv94,
Motion library seems not to be compatible in pure 64 bits. (I read that here)
Romain P.
National Instruments France
